saurabh252
Newbie level 6
I have a 5 pin leone relay (coil :6v DC)
The problem is when ever i connect A & B terminal(coil) directly to 9v cell it works as it should..
but when i put it in my circuit it does not work..
my circuit is very simple 555 timer..
i have connected pin 3 of 555 with resistor(220 ohm) ,led only( it works ) and when i replace led with a relay(with protection diode) it does not work..
if i put led instead of relay, led goes on/off perfectly..
out put voltage at that terminal shows 7.5 volts..
so relay is working with 9v cell but not with circuit and led is working with the circuit..
i am not able to figure it out so help me as soon as possible..
