a.periz
Newbie level 3
- Joined
- Oct 22, 2009
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,307
Hi!
I'm making a system supplied by a DC 12V bus via a CAT5 cable.
I have many modules connected in series:
Supply -> mod1 -> mod2 -> ... -> modN
Each module has a mcu supplied by an 5v LDO (e.g. 7805) that drive a relay.
My problem is: the bus voltage lower with the distance because of the resistivity of the cable, so, it is better to choose a 12V relay (that works up to 9V) or a 9V relay and supply it with an higher voltage?
I'll use this family:
https://www.farnell.com/datasheets/1019795.pdf
Thank you
Andrea
Thank you
Andrea
