kakiitek
Junior Member level 1
Hi all,
Is the maximum load capacitance in any way related to the configurable drive strength on output pin?
This is what I understand -
1. As long as the total output capacitance of input pins are below the max capacitance of the output pin, the AC specification of the chip will be valid.
2. When the total output capacitance exceeded the max capacitance of the output pin, we need to check on the delay due to this additional capacitance. For slower speed communication, this should be fine assuming we are operating within the timing specification.
3. Setting a higher drive strength would decrease the rise/fall time.
Question -
Does setting higher drive strength helps to reduce the delay caused by high total load capacitance?
How are these two related or are they related at all?
Thanks.
kakiitek
Question -
Thanks.
kakiitek
