[SOLVED] Relation of PSRR at DC to loop gain
diarmuid
Full Member level 2
Full Member level 2
Dublin, Ireland
Hello All,
Just wondering if anyone has an explanation for this:
I am looking at the PSRR at DC of a V2I converter, basic schematic attached.
The loop gain at DC is 90dB. However, my PSRR at DC (taken at the top of the resistor) is 80dB.
Does this make sense? I would have thought the PSRR at DC should equal the loop gain at DC.
Any ideas where I am going wrong here?
Thanks,
Diarmuid
  • V2I_PSRR.pdf
There's no direct connection between open loop DC gain and PSRR at DC (better: at low frequencies: DC is static, no change, so no influence on the output).
You can say the PSRR at any frequency - in a first order approximation - will be approved by the (neg.) feedback size, i.e. by the ratio open-loop_gain/actual_gain. As your amplifier has full feedback and runs with gain=1 , measured low-frequency PSRR of 80 dB at gain=1 means a 80-90=-10dB low-frequency PSRR at open loop.
PSRR taken as 20*log(power_supply_interference_voltage/output_reaction_voltage).
Yes, as described in Willy Sansens Analog Design Essentials: PSRR = Avol/Avdd. In my case, my Avol was 90dB but my Avdd was 10dB (output stage of opamp was gaining up the noise seen
at the output). This is where the 10dB was going.
