Relation between dynamic and memory fragmentation
JaMe
Junior Member level 1
Indonesia
what is the relation between dynamic and memory fragmentation ? Is something like that could occur in AVR microcontroller?
Hi
If you mean Dynamic allocation , yes
Dynamic allocation will lead to memory fragmentation.
and you need a garbage collector .
to avoid this you can use memory pools with different sizes to make allocation from.
Regarding AVR I don't know , but basically it could happen.
In Embedded Systems program should work for ever so memory fragmentation could happen with hi probability, it's better to calculate your memory needs before compiling your code and allocate your memory staticalley.
Salam
Hossam Alzomor
www(.)i-g(.)org
    JaMe
Dynamic memory allocation happens on the heap.
As a microcontroller has no inherent OS, the heap will only exsist if you create it in code and use dynamic memory algorythms. Unless you are using an RTOS or OS, you have control over the memory.
