Akshay2waghamare
Newbie level 2
I am designing the circuit with voltage divider and loads after it but i am not getting how to design the circuit of voltage divider with less power dissipation in resistors
There is no question, so how can we help you?I am designing the circuit with voltage divider and loads after it but i am not getting how to design the circuit of voltage divider with less power dissipation in resistors
If you want us to help you with the calculations, you first need to priovide the requirements, specifications, mainly as values with units..
And (hand-) draw a simple schematic.
Try to give all informations at once.
Klaus
But you need to drop a lot of voltage: 42V - 5V = 37V. (in resistor or other linear devices) this means the dissipated heat is 37V x 0.5A = 18.5W
Klaus
What's upstream of the 30Vac supply? Is it a line -frequency transformer connected to mains? If it is, then just go for an flyback converter. With 5V/500mA output, a DCM offline flyback would suffice, else a 5V/500mA output dc/dc buck converter would do.
