milind.a.kulkarni
Advanced Member level 3
Hello To all,
I have one fundamental doubt - In case of AC winding used in machine like transformer coils used in primary or secondary winding ..... if there is a multi-turn coil need to be used ( most practical scenario) ..... What is the proper method of winding ?..... I had seen lot of videos on this but .....I have following doubt....
- In the videos - In the winding of the coil...... the winding of the first layer, turns are wound from bottom to top..... and then in next layer of the winding....the turns of the winding are wound from top to bottom.....Is this is right way ?
- Or do we need to maintain the direction of winding same .... I mean if we wound the first layer Let say from bottom to top direction...... then for next layer..... every time take a single cross winding thread down to bottom...... and wind the next layer of winding from bottom to top again....
Please share your valuable review on this...
Thanking you in advance....
With regards,
Milind
With regards,
Milind
