chuckis
Newbie level 2
![Newbie level 2](/styles/images/ranks/alevel2.gif)
Good evening, this image
is a voltage regulator can maintain constant supply voltage to the input of the integrated circuit of the RFID tag
but I fail to understand its working principle.
in the article it says that the system is a kind of negative reaction system cons, the problem is that I see no mm exit system
I decided to made to vary the voltage at point A as the input of the system, but the problem is that I do not see on the diagram output of the system.
or if a regulator requires an input voltage and output variable which is fixed.
thank you in advance
![78_1307470924.png](https://obrazki.elektroda.pl/78_1307470924.png)
