kukurio
Newbie level 2
I'd like to make a power supply that takes in two DC inputs and either adds them together or just puts out one of them, depending on the logical value of an additional gate input. (Essentially, one of the inputs represents a DC offset and the other represents a gated AC.) The output voltage range should be 0-20 V and 0-2 A. I thought I'd be able to do this with a MOSFET, but I'm not really a circuits guy and hit a dead end when I realized that power FETs aren't really bidirectional, so a strong source-to-drain voltage will also conduct when the gate is off.
I saw on Digikey that there are diode laser drivers that can do something like this, but the currents are too low, probably because the frequency at which they switch is ridiculously high for my application (> 10 Gbps, when I need ~100 kHz). Does anyone have any ideas for a circuit that can do this? Alternatively, is there an IC type that already does this whose name I am just unaware of? I'm very overwhelmed by Digikey's selection. Thanks.
