rtypeg
Newbie level 1
Hello all,
I am attempting to power a simple ~12V motor with a battery, and regulate its speed using a photoresistor, such that under high light conditions the motor turns quickly, but under low light conditions the motor turns slowly or not at all.
I was able create a circuit using batteries, a resistor, and a photo-resistor similar to whats above. The output would be high (around 12V) in light and low (< 3V) in dark.
The problem arose when hooking up the motor inputs to this voltage output. Simply put, the motor didn't turn. The voltage at the motor input dropped to around 4V or 5V when the motor was connected.
I tried using an op-amp to buffer the output of the photo-resistor circuit, but the motor still won't turn. I'm not sure if it unable to draw enough current or what.
The motor turns perfectly when connected directly to the battery.
If there is a way to fix this, or an easier way to accomplish this, please let me know.
Thank You
Thank You
