Registerd FSM outputs
sunidrak
Full Member level 1
Full Member level 1
Bengaluru, India
I recently read abt registerd FSM outputs i.e Registered Moore outputs and Registered Mealy Outputs , Can anybody explain wat is FSM output registered ?
I did verilog coding for 1011 Sequence detector for both moore and Mealy machine and I got the output like in the Image there is one clock dealy in the moore is it correct ??
Can anybody explain the Registered FSM outputs wat is the difference with this output
module mealy1011(clk,rst,inp,outp);
input clk,rst,inp;
output reg outp;
reg [1:0]state;
parameter S0=0, S1=1, S2=2, S3=3;
  always @(posedge clk or posedge rst)
    if(rst)
      state<=S0;
    else
      case(state)
        S0: if(inp)
              state<=S1;
            else
              state<=S0;
        S1: if(inp)
              state<=S1;
            else
              state<=S2;
        S2: if(inp)
              state<=S3;
            else
              state<=S0;
        S3: if(inp)
              state<=S1;
            else
              state<=S2;
  endcase
always @(state,inp)
      case(state)
        S0: if(inp)
              outp<=0;
            else
              outp<=0;
        S1: if(inp)
              outp<=0;
            else
              outp<=0;
        S2: if(inp)
              outp<=0;
            else
              outp<=0;
        S3: if(inp)
              outp<=1;
            else
              outp<=0;
              endcase
endmodule
module moore1011
  (input clk, rst, inp,
  output reg outp);
  reg [2:0] state;
  parameter S0=0, S1=1, S2=2, S3=3,S4=4;
  always @(posedge clk, posedge rst)
  if(rst==1)
    state<=S0;
  else
    case(state)
        S0: if(inp)
          state<=S1;
        else
          state<=S0;
        S1: if(inp)
          state<=S1;
        else
          state<=S2;
        S2: if(inp)
          state<=S3;
        else
          state<=S0;
        S3: if(inp)
          state<=S4;
        else
          state<=S1;
        S4: if(inp)
          state<=S0;
        else
          state<=S2;
        endcase
  always @(state)
        case(state)
        S0:
          outp<=0;
        S1:
          outp<=0;
        S2:
          outp<=0;
        S3:
          outp<=0;
        S4:
          outp<=1;
        endcase
      endmodule
