Regarding to the MAX232 board
SINDHURI
Member level 2
Member level 2
Good Morning one and all,
Is it possible to connect a DB9 Connector at the output of the MAX232 Board. Please any one can help me quickly.
Thanks in Advance.
MAX232 Examples
MAX232 circuit:
If there is no MAX232 this can help:
Best regards,
Peter
:wink:
For first circuit shard by tpetar, if you want to communicate between your PC and ucontroller you should use null modem connection, google it , its construction is simple.
tpetar,
Unless be powered by negative supply instead GND, 2nd circuit will not work due to RS232 standard voltage level requirements.
[-12,-3] <--> [+3,+12]
I tried perform mentally a circuit working simulation and did not understand how this capacitor could be reversely polarized.
