regarding multiple clock
venkatramanan
Member level 4
bangalore
I am having multiple clocks..how to handle those clocks?
how i have to manage those clocks?
can u any one explain me...
Hai venkat,
For managing two clock u can define like this sdc file...
EX;-
create_clock -name "firstclock" -add -period 2.0 -waveform {0.0 1.0} [get_ports firstclock]
create_clock -name "secondclock" -add -period 2.0 -waveform {0.0 1.0} [get_ports secondclock]
or else u are asking about how to manage the clock timing in STA?????? .. I cant predict the question??
This may help...... Thanks :razz:
when you have multiple clocks, one question rise asynchronous or not?
how to manage the clock timing?
---------- Post added at 13:32 ---------- Previous post was at 13:31 ----------
not synchronous
Hai venkat,
Clock timing depends on the specification file... Also additional to that if u have problem in timing analysis....
EX:- Consider u are having a negative slack in clock path....
If so add buffer deletebuffer upsize downsize etc... to meet the timing
This may help...
Also , I will recommand you to use global clock lines for routing the clock........with BUFG ( global buffer) .....how ever there will be skew but mostly will be in limits..... Also put some RLOCK constraints in UCF /SDC file....
Good Luck
