Regarding IF amplifier selection to amplify I and Q analog IF signals
Maitry07
Full Member level 3
Full Member level 3
Hello support team,
I have a requirement to amplify my I,Q signals simultaneously . MY I,Q frequency range is 1 MHz to 30 MHz. I want to use identical analog IF amplifier to amplify my analog I and Q signals. as analog components have slight mismatch . I do not want that this slight mismatch affect my I,Q signal and add amplitude and phase imbalance. so, For this kind of applictaion, the IF amplifier should have dual identical channel in a single IC. Can you suggest this kind of specific IF amplifier having dual identical channel for I and Q signal amplification?
LaTeX Commands Quick-Menu:
