[SOLVED] Regarding for loop in verilog
dhivya34
Junior Member level 1
When I use the normal for loop in verilog with the loop variable declared as a wire I get the following error
'i' is an invalid type in Generate loop. Must be a genvar
Hence I changed the loop variable i as genvar. I got the following error.
The for-generate loop scope genblk1[2] already exists
Help me fix this!
declare i as integer
ex: integer i;
for(i=0; i<x; i = i+1)
begin
end
u need to put the for loop inside always or initial block.
Reactions: ruwan2
    ruwan2
Thanks.
But then also I got error.
The function of for loop in my code was to assign values to different bits of the same variable according to some rule.
Hence I had to enclose 'for' within a generate block and name the block to get rid of the error.
