Maitry07
Full Member level 2
Hello,
I am planning to use DAC having the output range of 0 to 10 V with 14 bit resolution. ( if my DAC is having 2.5 V reference voltage)
so, my DAC output voltage will be =[ (2.5)/2^14-1 ]* digital data input
As my digital data input Hex value range is in between : 0x0033 to 0x0FE4 having the variation of 0x0033, 0x0034, 0x0035... and so on.
so, based on the hex values at the input of the DAC with having the reference voltage of 2.5 V and 14 bit resolution, the DAC output voltages will be
0.007906177 V, 0.007997726 V, 0.008090335 V,..... up to 0.620821168 V .
So, If I want to increase the ratio between 2 DAC output voltages and want to use the full range of DAC : 0-10 V , could you please provide guidance on type of signal conditioning to be used at the output of DAC?
Awaited your response.
