yviswanathbe
Full Member level 4
Can some body help on the following.
I have a battery with 12 cells(each 1.8V) connected in series. I am designing Battery Monitoring System with LTC6802-1, Battery Stack Monitor(linear Technologies). as per the recommendation from linear tech i have connected all the cells with a Low pass Filter to the LTC chip (R=100ohm and C=100n).
Now i want to calculate power rating of the resistor and the maximum voltage.
if i have chosen 0.25W as power rating, the maximum Voltage to be applied to the resistor is
square root(P*R). Therefore max Voltage = 5V. But at the 12th cell the voltage will be 18V.
is this right? if i am wrong some body please correct and tell me how can i choose the resistor (both power rating and Voltage).
Thanks and Regards,
Viswanath
Thanks and Regards,
Viswanath
