Top view is when you look at it from the side where the IC number is printed. The pin numbers start from the left. Like this -my doubt is that , in the pin connection diagram that is given in datasheet is front view of op-amp or back view of op-amp. i am confused in getting pin numbers. in the diagram it is given that top view. what is the meaning of top view
my problem is to amplify a 1V ac signal to 15 V AC signal with 1AMP current capacity.
