johnson.mike
Full Member level 1
- Joined
- Nov 29, 2007
- Messages
- 96
- Helped
- 8
- Reputation
- 16
- Reaction score
- 6
- Trophy points
- 1,288
- Location
- Around the world
- Activity points
- 1,766
I want to match input impedance of a chip antenna (2.4-2.5GHz).
Below fig shows the layout.
I measured antenna impedance as 20.12-j82.6 Ohms and impedance of the input transmission line terminated with 50 ohm resistor at load end is 44.4-j12.3 Ohms.
I've calculated matching component values as ( seriesL=6.8nH and shunt C=1.6pF) using winsmith.
Using above values the total impedance is 20 Ohms.
What might be the problem?
Whether the calculated values in Winsmith was right?
Give suggestion for matching antenna impedance.
regards,
Johnson.
regards,
Johnson.
