jayanthi
Junior Member level 2
Respected sir,
i am having doubt in the fabrication of PIFA antenna. actually it contains both the ground plane and the radiating patch and the shorting pin connects the ground plane and the radiating patch and one coaxial probe feed is from the ground plane to the radiating patch.
While preparing mask upto my knowledge we have to provide a hole for probe feed in both the ground plane to the radiating patch.suggest me in this regard . and for connecting the short pin between the ground plane to the radiating patch what should i do while preparing mask, whether the hole is needed in both th planes for this short or not.
with thanks
N.Jayanthi
with thanks
N.Jayanthi
