AOQ
offset-voltage gain adc preamp comparator
Dear all :
I am designing a 10b single-ended, charge redistribution type SAR ADC in 0.35um CMOS.
Supply voltage is 3V and power budget is 100uW.
Conversion rate is 10~100KSPS.
I hope to achieve rail - rail input range, thus I need a voltage near VDD/2 for the preamp of comparator, for proper input common mode range.
My question is, in order to save power, i dont want to design a bandgap on chip. Since this voltage is just applied to the gate of preamp , is it suitable if I simply use two large caps (like 5pF) as a voltage divider to generate VDD/2 durning sampling phase ?
If not, is there any method to achieve rail-rail without using offchip reference ?
Another question, as far as I know, comparator offset does not affect the linearity, offset cancellation is not necessary. So why should we design a comparator using two low gain preamps instead of high gain one ? for higher resolution ?
What is the main parameter to determine comparator resolution ?
From simulation, a single dynamic latch without preamps can tells the difference about 0.1 mV !? It seems impossible ....
Should I do the overdrive test to see the resolution of my comparator for
SAR ADC?
Big thanks
Dear all :
SAR ADC?
Big thanks
