nxing
Advanced Member level 1
Hello everybody,
I got confused by one simple question and hope some body can provide some ideas:
I want to design a ADC with differential input (each of them)between +,- 500mv. Also, I will put two reference voltage, say "refp" and "refn". My question is which value I should setup refp and refn. If I set rep = 500mv and refn =-500mv, then, the differential value of input signal will between +,- 1v. If I set refp=1v and refn=-1v, each input signal will not exceed
+,- 500mv. What's the correct choice?
Thanks
Thanks
