rmanbike
Newbie level 3
Please help me in figuring the correct size resistor to reduce 2.3 dc volts down to 1.3 dc volts. This is circuit board of a thermostat/thermidistat, which includes a Honeywell HiH-3610 humidity sensor. The documentation for this is here: **broken link removed**.
Background;
The thermostat for my Carrier hvac system has a maxium set point of up to 45%, I would like to increase this to 60%. The only way I can think of to do this is to install a resistor in the output voltage of the humidity sensor to reduce the voltage about 20%.
If this doesnt work I will have to replace the Carrier thermostat for a Honeywell thermostat which has a humidity level set point of up to 60%. But I will loose the functionality of the variable speed/output gas furnace.
Background;
