stanislavb
Full Member level 2
I need reduce parasitic capacitance for long traces- about 500mm.
We did follow
a.Reduce trace width according existed technology technology - 2.5 mil
b.Make ground plane as far as possible
c.Instead solid ground plane using grid.
The PCB stack up as follow
1.CS
2.Digital PLANE
3.Digital signal
4.Digital signal
5.Digital PLANE
6.Digital PLANE
7.Analog PLANE(power)
8.ANALOG GND
9.ANALOG TRACE
10.ANALOG TRACE
11.ANALOG TRACE
12.ANALOG TRACE
13ANALOG GND
14.Analog PLANE(power)
15.digital PLANE
16.digital PLANE
17.digital Signal
18.digital Signal
19.digital Plane
20.PS
We are interesting to reduce parasitic capacitance for ANALOG TRACES layers. These traces referenced to ANALOG GND layers. What is yours recommendation?
What do you think if we add two solid metal layers connected to nothing between 8 and 9 layers and between 12 and 13 layers. This layer will service as shield for electromagnetic field.
Thank you
We did follow
1.CS
2.Digital PLANE
3.Digital signal
4.Digital signal
5.Digital PLANE
6.Digital PLANE
8.ANALOG GND
9.ANALOG TRACE
10.ANALOG TRACE
11.ANALOG TRACE
12.ANALOG TRACE
13ANALOG GND
15.digital PLANE
16.digital PLANE
17.digital Signal
18.digital Signal
19.digital Plane
20.PS
Thank you
