reduce noise in Amplifier Stage
OvErFlO
Full Member level 3
Full Member level 3
I have this configuration, I have see a little output noise (Vpp_noise = 100mV) on the first AOP.
(see image below)
The second amplify is a AOP inverted mode with an Vo = -10* Vi, my second amplify bounce also noise, there's a metod to reduce noise ?
thanks
100 mV is pretty large. Maybe using ideal op-amps could isolate where the noise is coming from?
Try adding some capacitance at that node to see that helps.
Dear OvErFlO:
Please tell the start and stop frequency.
But 100mV is really large.
You might want to check correctness of the noise model
by simulating stand alone transistor.
