19127916
Hello,
I have designed a doubler rectifier with a Pi-shaped matching network.
in my first design, I did not use the short copper connections required for fabrication and I got acceptable results. The problem is that when I added short coppers the S11 is still the same but I lost the efficiency (the efficiency dropped from over 35% to about 1.5%).
I would be thankful if anyone can help me with the problem.
First design without short coppers after the rectifier:
The second design that the efficiency dropped:
