Recording continuous digital data
JiL0
Member level 1
Member level 1
I'm currently trying to collect lots of digital data from my ADC. I need the data to conduct a histogram test. As I need to collect total data (continuous) in the region of 100,000, it is not possible to collect the data manually. Would like to ask if anyone have done it before and how did you all do it and with what equipment?
Hope someone can help. Thanks in advance
You will need to use a data logger.
You can buy them of-the-shelf ( https://www.picotech.com/data.html, ....) or you can use PC with Data Acquisition Card, for example from National Instruments, and write or find application software for this card.
Can you tell us what you already have?
You want to build a logging device or buy one?
If you want to build one connect ADC to a memory module so you can play back later. You also can have a Logic Analyzer, connect to oscilloscope and record the samples with a lot of precision.
