Aussie Susan
Advanced Member level 5
My current circuit has a wireless battery charger (BG51050B) that charges a single cell Li-ion/LiPo battery. That part works well.
I also have some circuitry on the 'other side' of the battery (a PyCom GPY and a GPS receiver) that are more than capable of working well below the appropriate Li-ion battery cutoff voltage. This means that I have ruined 1 battery by over discharging it.
What I'm looking for are circuit designs or ICs recommendations for something that will:
- allow the 'working part' of the device to be powered when the battery is above the minimum voltage (say 3.2V or whatever is the recommended lowest discharge voltage) - this also means that it should come on while the battery is charging on the wireless pad
- shut off the rest of the device when the battery is to low so that it will not discharge further (i.e. as low as possible stand-by current from the voltage monitoring hardware)
It is for a home-made GPS tracker for my dog and so it will only be used occasionally and I'm happy to put it on the charging pad before use. As my dog loves the water I am trying to make sure the container is as waterproof as I can make it so I don't want an external switch.
I've looked on the Internet and seen lots of designs for battery chargers so I could well be using the wrong searching terms.
Susan
Susan
