When talking about power supply .. we don´t need to know hwat these devices do .. we need to know their current consumption.
Also it does not matter what bus they ouse or whether they are on one or many PCBs.
Only the current counts.
Which additional sensors?
My colleague and I have no information, we were told that the supply voltage is 3.3 volts. We have requested more information.
What´s your idea how to do the switch over between 5V and 12V sources
My colleague is working on this task. We made our proposal to have a single 12 volt input source.
I´m not sure if the LDO is the right choice. the LDO waste 50% of target power .. to generate heat. Neither heat is a good thing nor wasting energy ... Especially if the 12V is from a battery.
We need the currents .. and we need your goals and requirements.
5 volts-0.5A, 3.3 volts-0.05A, 3.3 volts-0.07A, 3.3 volts-0.08A, 3.3 volts-0.1A. I described the goals and requirements at the very beginning.
Chip count does not matter. EMI is is more a problem of PCB layout and part selection.
PCB layout: one really SOLID GND plane, short current loops, small area of current loops.
OK. Thank you
What is a ripple blocker? How much ripple do you expect (from which source) and how much ripple do you allow?
Detailed information https://www.digikey.com/es/product-highlight/m/micrel/ripple-blocker
I´ve done many really noise sensitive nalog/digital designs.. if I´m not mistaken all with DC/DC switchers. Usually the 16 bit ADCs work in my application within the specified performance fo the datasheets. So the DC/DC noise is almost neglegible.
Since you did neither mention sensitive nor analog circuitry .. I see no problem for a purely digital application at all.
My colleague is responsible for analog and digital design. I'll check with him for more information.
Klaus
