Recommend me hard disk image handling software
artem
Turkey
Hard disk Image handling
Could someone recommend good hard disk imagehandling soft for fast backup and restore .
The one I know is PowerQuest .
And is there console based application not requiring windoz to rely on .
Let say allowing to make backup to nonsystem disk and restore from there in dos mode from bootable disk
Thank you in advance
Norton Ghost
Re: Hard disk Image handling
Hd98copy
Drive Imge can restore from bootable disk. The program makes 2 diskettes and you can restore image file from the environment which the bootable diskettes creates.
It is good that if you have the diskettes it is not necessary to install the program. You can select wich drive to create as an image.
Thanks guys for response .
There is a link :
'Acronis true image 7" is considerated to be the best one !!!
:D :D :D
Bye!
