Recommend me a architecture for low power oscillator design
nijMcnij
Full Member level 1
Full Member level 1
Hello all,
can you please recommend a suitable architecture for an ultra low power, low frequency (50Khz), and modest phase noise requirement.
many thanks
Re: oscillator design
since the osc frequency is not high, maybe Gm-C structure is a choice.
oscillator design
ring osc such as inverter chain or delay cell
oscillator design
there are different oscillator which you can use for ur purpose.
if it is for non sensitive purpose, you can use any LC oscillator.e g: Colpit osc, or Hertley osci
but you can also use a ring osci
Due to the low frequency, if you use LC type the area is very large.
If you use ring oscillator, you may need many stages.
I suggest you can use relax RC type oscillator.
The area can be smaller than other ones.
Yibin.
I am sure you can get such circuits in the market.
The frequency is very very low, have you thought of using an A-Stable?
thank you all for your input,
indeed i have considered A-stable and ring oscillators, but they produce digital signals, i need a sin wave.
any comments?
any comments?
Gm-C osc circuit genetates the sine wave, you can try it.
thank you iamxo for your comment.
can you recommend a good reference for an ultra low power, low frequency gm-c oscillator?
