Recommend components for Load Cell Amplifier
Sobakava
Full Member level 6
Full Member level 6
I need to design a good (low noise, good linearity) load
cell amplifier and digitize it in >16bits.
Which sigma-delta ADC do you recommend?
:?: Which instrumentation amplifier do you recommend? I am
trying Texas Instruments INA125 because it has its
own voltage reference.
It should be low cost and good performance.
:D
ina125 pic
two names come to my mind. both have a built in programmable gain amplifier
ad7730
cs5520
you can search google for both's data sheets
Hmm,
I built a circuit with a 16f877A and i can measure pressure with a load cell.It works perfect.Maybe you want to try it.
Analyzer.
load cell amplifier
I need 16bit resolution at least. I am looking for 16 and
24bit ADCs. Did you implement software sigma-delta
with PIC16F877's 10bit internal ADC?
I am also planning to use PIC (18F458) and CAN or
RS485 for transmission.
Yea,
I use ccs c compiler and their official board has many helpful member.I just asked them.Try to ask them. www.pic-c.com/forum But if you need 16bit or higher 877 does not work :(
Analyzer.
Re: Load Cell Amplifier
I try Ina118 Ina125 ad524
but i found ina118 is the best from them
its the same in th datasheet
hi friend
i am using mcp 3551 adc for my load cell for that i dont have an
amplifier will you pls. help me on ina125 (circuit diagram)
---------- Post added at 13:29 ---------- Previous post was at 13:24 ----------
use mcp 3551 22bit adc you will find this adc in M/s silicon components ltd in andheri mumbai
ad7730 with pulse modulation is the best i have ever seen. One of my friends do some industrial boards with ad7730.
Hello,
bhushan_27
what u need to know in ina125 my friend ? i see that ina118 better ..
Zerox100
how many bits ur friend have ???? did he get more that 14 bits ???
