sefton
Member level 2
pcb l4978
Can someone recommend a DC-DC step down converter IC which works at a high switching frequency, uses few components and is not too expensive. I require a high switching frequency (about 1 Mhz) so that the components will be small. Specs: Input 12V, Output 5V @ 1A and 3.6V @ 1A.
I can use either a dual converter or 2 single converters.
The LT1940 is perfect except that it is quite expensive - about $7 over here.
Any suggestions ?
Any suggestions ?
