Wajiduddaim
Junior Member level 1
- Joined
- May 12, 2011
- Messages
- 18
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- darbar-e-Sadria
- Activity points
- 1,464
HI
i m making a circuit of GSM/GPRS module SIM868 according to this **broken link removed**.
but i have a problem with VRTC (backup battery).if there is rechargeable battery will module will charge it, if yes then afrer fully charge, will module auto stop it?
if module didnt charge the battery the which circuit is suitable and which battery is recommended.
Battery info from DataSheet
6.3. Backup Power of GNSS
Power source (such as battery or LDO) connected to VRTC pin will help the GNSS chipset keep its internal RTC running while the main power source is turned off, this will help to short the cold start time. The voltage should be kept between 2.3~4.3V, and the typical value is 3.0V.
