RECEIVING INFORMATION on PC FROM MICROCONTROLLER BY RS232
tusemo
Full Member level 1
Turkey
Does anybody have (or know) visual c sharp code to receive data from rs232 ?
It's not that difficult to write. You have to open the MSComm port and set the parity, baudrate, stop bits. and then transmit / receive data. If you want I can try. I have done that in VB.net
Try this app to receive serial data.
  • serial receive.rar
  • Serial Communication.rar
is it possible to sen information to pc what ever I want (no time restristion) ?, Should I use 9-pin serial port's some pins more than Rxd and Txd
Reactions: tusemo
    tusemo
If your PC does not have a serial port (most computers nowadays don't), you have to either use USB or a USB-to-RS232 converter and then use RS232.
