[PIC] REceive uart data as hex value
ajit_nayak87
Member level 5
Member level 5
I am using Mplab x Ide with v3.61 on Xc8 compiler, PIC18F24K40. I used MCC generated UART code for send and receive data. For understanding I am clubling my code and posting part of it.
My main code look like this.
#include "mcc_generated_files/mcc.h"
#define EUSART_TX_BUFFER_SIZE 8
#define EUSART_RX_BUFFER_SIZE 8
  Section: Global Variables
volatile uint8_t eusartTxHead = 0;
volatile uint8_t eusartTxTail = 0;
volatile uint8_t eusartTxBuffer[EUSART_TX_BUFFER_SIZE];
volatile uint8_t eusartTxBufferRemaining;
volatile uint8_t eusartRxHead = 0;
volatile uint8_t eusartRxTail = 0;
volatile uint8_t eusartRxBuffer[EUSART_RX_BUFFER_SIZE];
volatile uint8_t eusartRxCount;
#define LED_RX RC7 // Pin assigned RX LED
#define LED_TX RC6 // Pin assigned TX LED
#define LED RC2 // Pin assigned for LED
#define DE RC5
unsigned int count=0;
char data=0;
static int DEVICE_ID=1;
char rxbuf[50]=" ";
unsigned char Function_code=0X03;
static int index=0;
static int rec_flag = 0;
static int check_flag = 1;
unsigned char buff[10];
char data1[10];
unsigned char buf[20]; //array to hold twenty bytes
void EUSART_Initialize(void)
    // disable interrupts before changing states
    PIE3bits.RCIE = 0;
    PIE3bits.TXIE = 0;
    // Set the EUSART module to the options selected in the user interface.
    // ABDOVF no_overflow; SCKP Non-Inverted; BRG16 16bit_generator; WUE disabled; ABDEN disabled;
    BAUD1CON = 0x08;
    // SPEN enabled; RX9 8-bit; CREN enabled; ADDEN disabled; SREN enabled;
    RC1STA = 0xB0;
    // TX9 8-bit; TX9D 0; SENDB sync_break_complete; TXEN enabled; SYNC asynchronous; BRGH hi_speed; CSRC master;
    TX1STA = 0xA4;
    TRISCbits.TRISC7 = 1; //As Prescribed in Datasheet
    TRISCbits.TRISC6 = 1;
    RC1STAbits.CREN=1;
    TX1STAbits.TXEN=1;
    // Baud Rate = 9600; SP1BRGL 207;
    SP1BRGL = 0xCF;
    // Baud Rate = 9600; SP1BRGH 0;
    SP1BRGH = 0x00;
    // initializing the driver state
    eusartTxHead = 0;
    eusartTxTail = 0;
    eusartTxBufferRemaining = sizeof(eusartTxBuffer);
    eusartRxHead = 0;
    eusartRxTail = 0;
    eusartRxCount = 0;
    // enable receive interrupt
    PIE3bits.RCIE = 1;
uint8_t EUSART_Read(void)
    uint8_t readValue = 0;
    while(0 == eusartRxCount)
    readValue = eusartRxBuffer[eusartRxTail++];
    if(sizeof(eusartRxBuffer) <= eusartRxTail)
        eusartRxTail = 0;
    PIE3bits.RCIE = 0;
    eusartRxCount--;
    PIE3bits.RCIE = 1;
    eusartRxBuffer[8];
    return readValue;
void EUSART_Write(uint8_t txData)
    while(0 == eusartTxBufferRemaining)
    if(0 == PIE3bits.TXIE)
        TX1REG = txData;
    else
        PIE3bits.TXIE = 0;
        eusartTxBuffer[eusartTxHead++] = txData;
        if(sizeof(eusartTxBuffer) <= eusartTxHead)
            eusartTxHead = 0;
        eusartTxBufferRemaining--;
    PIE3bits.TXIE = 1;
char getch(void)
    return EUSART_Read();
void putch(char txData)
    EUSART_Write(txData);
void EUSART_Transmit_ISR(void)
    // add your EUSART interrupt custom code
    if(sizeof(eusartTxBuffer) > eusartTxBufferRemaining)
        TX1REG = eusartTxBuffer[eusartTxTail++];
        if(sizeof(eusartTxBuffer) <= eusartTxTail)
            eusartTxTail = 0;
        eusartTxBufferRemaining++;
    else
        PIE3bits.TXIE = 0;
void EUSART_Receive_ISR(void)
    if(1 == RC1STAbits.OERR)
        // EUSART error - restart
        RC1STAbits.CREN = 0;
        RC1STAbits.CREN = 1;
    // buffer overruns are ignored
    eusartRxBuffer[eusartRxHead++] = RC1REG;
    if(sizeof(eusartRxBuffer) <= eusartRxHead)
        eusartRxHead = 0;
    eusartRxCount++;
/* Send Data Serially */
 void send_string(const char *x)
     while(*x)
        EUSART_Write(*x++);
/* Timer Interrupt Service Routine Program*/
void Blink_Count()
   if(PIR0bits.TMR0IF == 1)
       PIR0bits.TMR0IF =0;
       count=count+1;
       if(count>=15)
          // LED=!LED;
           count=0;
void main(void)
    while (1)
   data= EUSART_Read();
     rxbuf[10]=data;
     printf("%s\n",&rxbuf[10]);
     __delay_ms(150);
And tested Serial communication. with this code i could print welcome on Serial Monitor
void main(void)
  EUSART_Initialize();
    while (1)
     char array[20] = "Hello World";
     printf("%s\n",array);
      __delay_ms(150);
The problem i am facing is. When i try to send data 0103000000Ac5CD In ASCii format i receice as charcter ,but when i try to send in hex format i could not able to receive nothing. If am printing data like i used in working hello print example i got garbage value. Helloword.jpgUart_out.jpgRs485+format.jpg
my questions:
1) how to receive data from uart as string
2) how to receive hex value.
What is "0103000000Ac5CD"?
I assume it is a string...and a string already is a array of ASCII characters.
I don't kniw if this is your problem..
But there are (at least) two types of how a string is stored:
* one type has only one byte per character
* and the other has two bytes per character.
You need to read compiler documentation. Maye you can adjust it.
Klaus
hello,
Where is defined Lt ?
i don't undestand this
maybe this could be more correct ?
if((sizeof(eusartRxBuffer) & lt )== eusartRxTail)
use sprintf of c stdio library
