[SOLVED] Realtek Ameba RTL8195 cant drive a LCD?
Michael1991
Newbie level 3
Newbie level 3
The video shows the LCD running.
So if your circuit does not run, you dud something wrong.
Unfortunately you don't show the "not working circuit".
This makes it impossible to verify / help.
Klaus
Thank you for the reply. I will double-check the circuit. Then upload my connections.
The is a Variable Resistor to adjust the screen brightness. So basically, it is the reason. The screen is too dark to see. I should have adjusted it.
