tofinhk
Member level 1
Dears,
I don't know where to post this message. If I post on the wrong place, please move this thread to a suitable place, thank you.
I am doing my Final year project. I use Analog Devices ADuC812 as the microcontroller to receive 3 channels of the analog signal, and convert to the digital signals. Then, I have to transfer the signal to PPC/Palm. (Actually, I want to collect the signal outdoor and do analysis in PC)
As the data size is not small, I need a PPC/Palm with external memory(SD/CF).
However, I don't know how to communicate with PPC/Palm. I have to write a program with receive the signal from serial port and store it to external memory.
I think several ideas to solve the problem, but both of the ideas raise other problems.
1. Use Palm with Serial Port. However, Palm with serial port are all old models and no external memory.
2. Use PPC with Serial Port. I got a HP JORNADA 680e with CF slot and serial port, but i can't find sufficient materials/documents for me to write a program.
3. Use Palm/PPC with USB. No serial port, but I think I can use serial to USB chip. However, I can't find a chip that is easy to driven by 8051 or even no need to drive it.
May I ask which one I should use ? and why ?
Thanks in advance.
Thanks in advance.
