Real time simulation in Proteus
Thomas Sabu Ichippillil
Cochin, Kerala, India
Dear all,
I would like to do the simulation in proteus in real time. Is it possible? If so, could you please help me to make it as real time.
Thanks in advance
what do you mean by that? you are eager to make the hardware and then test it through proteus ?? proteus is a simulator only .
if you are using Proteus to make circuit diagram and to see output than it will give output as hardware u mounted . if u have any problem in Proteus than press F1 for help queue and see some virtual simulator.
yes ir is possible
you can first check the datasheet of the hardware you want to simulate.
