Reading Serial Port and Plotting with Chart (C#)- textbox and chart!
ramv
Germany
Hello,
I'm trying to read a serial port data from a controller and plot it using chart. I could read the data from the controller and see the data in a textbox earlier. Now I'm trying to use a chart along with the textbox. There are complication when I'm trying to use both together. I get an exception because I'm trying "data = sp.ReadLine();" for chart. I'd like to keep the textbox just to verify what I'm plotting, but I understand that I can also do that using putty. There's no response even when I use only the chart to plot. And I cannot pin-point the problem. Because to my understanding I think I have followed the steps to establish it, but then I'm failing anyway! Please do have a look at what I have tried so far and please do let me know if I'm doing something wong.
Chart and Form1
namespace Serial_receive
    public partial class Form1 : Form
        string t;
        SerialPort sp;
        double rt = 0;
        //Boolean i = false;
        private string data;
        private DateTime datetime;
        public Form1()
            InitializeComponent();
            Control.CheckForIllegalCrossThreadCalls = false;
            // User can already search for ports when the constructor of the FORM1 is calling
            // And let the user search ports again with a click
            // Searching for ports function
            SearchPorts();
        private void Form1_Load(object sender, EventArgs e)
            comboBox1.DataSource = SerialPort.GetPortNames();
            timer1.Start();
            Text = "Serial Channel to FRDM-KW40Z";
        private void TextBox1_TextChanged_1(object sender, EventArgs e)
        private void timer1_Tick(object sender, EventArgs e)
            rt = rt + 0.1;
        private void chart1_Click_1(object sender, EventArgs e)
            ChartArea CA = chart1.ChartAreas[0];  // quick reference
            CA.AxisX.ScaleView.Zoomable = true;   // see small button on the horizontal scroll for reset??
            CA.CursorX.AutoScroll = true;
            CA.CursorX.IsUserSelectionEnabled = true;
            var dataBlocks = data.Split('\n');
            foreach(var block in dataBlocks)
                var numbers = block.Split(new[] { ' ' }, StringSplitOptions.RemoveEmptyEntries);
                rt += 100; //some time interval
                for (int i = 0; i<numbers.Length; i++)
                    double n = double.NaN;  //represents a value that is Not a Number. Field is constant
                    bool ok = double.TryParse(numbers[i], out n);
                    if (ok) chart1.Series[i].Points.AddXY(rt, n);
                    else
                        int p = chart1.Series[i].Points.AddXY(rt, n);
                        chart1.Series[i].Points[p].IsEmpty = true;
                        Console.WriteLine("well shoot! try again..");
Combox1 for listing available ports and connecting
private void button1_Click_1(object sender, EventArgs e)
            //comboBox1.Items.Clear();
            SearchPorts();
        void SearchPorts()
            string[] ports = SerialPort.GetPortNames();
            foreach (string port in ports)
                comboBox1.Items.Add(port);
        private void comboBox1_SelectedIndexChanged_1(object sender, EventArgs e)
            if (sp == null || sp.IsOpen == false)
                OpenCloseSerial();
        private void button2_Click_1(object sender, EventArgs e)
            // Catch exception if it will be thrown so the user will see it in a message box
            OpenCloseSerial();
        void OpenCloseSerial()
            try
                    t = comboBox1.Text.ToString();
                    sErial(t);
                    button2.Text = "Close Serial port"; // button text
                else
                    sp.Close();
                    button2.Text = "Connect and wait for inputs";   // button text
            catch (Exception err)   // catching error message
                MessageBox.Show(err.Message);   // displaying error message
        void sErial(string Port_name)
            try
                sp = new SerialPort(Port_name, 115200, Parity.None, 8, StopBits.One);   // serial port parameters
                sp.DataReceived += new SerialDataReceivedEventHandler(DataReceivedHandler);
                sp.Open();
                throw (new SystemException(err.Message));
Textbox and chart data and saving data as text file;
private void DataReceivedHandler(object sender, SerialDataReceivedEventArgs e)
            if (e.EventType == SerialData.Chars)
                if (sp.IsOpen)
                    string w = sp.ReadExisting();
                    if (w != String.Empty)
                        Text += "\r\n";
                        Invoke(new Action(() => TextBox1.AppendText(w)));
            chart1.Series["Data1"].Points.AddXY(rt, data);
            Invoke(new EventHandler(displayData_Event));
        private void displayData_Event(object sender, EventArgs e)
            datetime = DateTime.Now;
            string time = datetime.Day + "/" + datetime.Month + "/" + datetime.Year + "\t" + datetime.Hour + ":" + datetime.Minute + ":" + datetime.Second;
            //data.AppendText(time + "\t" + data + "\n");
        private void button3_Click_1(object sender, EventArgs e)
            SaveFileDialog saveFileDialog1 = new SaveFileDialog();
            saveFileDialog1.InitialDirectory = @"C:\Users\varman\Documents\";
            saveFileDialog1.Title = "Save text Files";
            saveFileDialog1.CheckFileExists = true;
            saveFileDialog1.CheckPathExists = true;
            saveFileDialog1.DefaultExt = "txt";
            saveFileDialog1.Filter = "Text files (*.txt)|*.txt|All files (*.*)|*.*";
            saveFileDialog1.FilterIndex = 2;
            saveFileDialog1.RestoreDirectory = true;
            if (saveFileDialog1.ShowDialog() == DialogResult.OK)
                File.WriteAllText(saveFileDialog1.FileName, TextBox1.Text);
                TextBox1.Text = saveFileDialog1.FileName;
Thank you very much for your time. Good day.
Cheers
I assume there is a problem with the data format.
What is the dataformat and protocol used for RS232?
..The text box usually needs pritable ASCII strings.
and what data format does the chart need?
Klaus
data comes from a 16 bit ADC. Earlier it had text with the values, for instance something like " raw adc value: 65535. But now I've replaced it to just the numerics.
Shouldn't you instantiate the "data = sp.ReadLine();" assignment just when the "if (sp.IsOpen)" condition is true ?
This doesn´t tell anything about the dataformat (via RS232), nor the protocol.
Klaus
Hi, Okay! I thought it doesn't matter, but it does. I've done just like u have said. But wouldn'tit just skip if sp.IsOpen is false?
Klaus
Hi, It's an uart over usb interface (16 bits resolution integers) and not rs232.
It seems you don´t know what data format it is.
At least I´v never seen an RS232 transferrring 16bit binary data. Most usual is 8 bits.
Then the dataformat or the parsing and conversion of data may be the problem.
Please learn about data format and how to convert them.
Klaus
