tremblaylaroue
Newbie level 3
I've done a digital tachometer using a PIC16F877 and an Hall effect sensor wich "sense" a small magnet attached to the engine shaft but I need to make it more "universal".
This tacho. is gonna be used with small gasoline engines wich don't have primary ignition coil signal available. What I'd like to use is to wrap a piece of insulated wire around the spark plug wire to make some kind of induction pickup. Easy and will work with any motor...
The problem is that I don't know how to filter this noisy signal to have some nice pulses for the PIC micro...
Any help will be apreciated !
Dany
Dany
