Reading Data from CPU
Hamed.H
Hi :D
I want to read CPU temperature from PC but not from out oh the Case in other words I want to read CPU temp. by means of microcontrollers or ... :arrow: AND How Can I ???
should this be an external sensor or the one onboard?
Dear eelinker and Anno I want to read that from registers or from internal mainboard I/Os , [not by means of sensors].
These sensors are usually board-specific.
meaning that you each board manufacturer will usually have own
means of reading data from the onboard sensors.
for example my Epox mother board's software to read CPU temp will not (most cases) work with other motherboards.
you will need some info on your board.
Good luck
OK, I see.
I will contect my mother board manufacturer.
Thanks alot
