[SOLVED] Reading a dip switch using one pin ?
henninggs
Member level 2
Member level 2
Denmark
Hi.
I am trying to design a simple rs485 slave. The slave will get its address from a 5 position Dip switch. It will only need to read the switch once: When it is powered on. (Storing the address in a register for later use)
I could dedicate 5 pins on the microcontroller to this purpose, but those 5 pins would be nice to have for other things once the PIC is done reading the address.
There is 2 solutions as I see it:
1. Use 5 pins for the read, then disconnect the dip switch from the pins. (How is that done ?)
2. Connect the switch to some resistors and dedicate a single analog-to-digital pin for the read. Convert the voltage drop to an address. Something like this:
What would be the best solution to my "problem" and how could it be done ?
Thanks for any replies.
Both solutions can work. For the 5 pin "digital" variant, you need a means to isolate the switches in normal operation, at least serious resistors, diodes or a multiplexer ic. The feasibility depends much on the regular function of the respective pins. It's probably more easy for pins that are used as outputs later.
The "analog" solution needs a sixth pull-down resistor, forming a voltage divider. The threshold voltages for the 5 bit decoder need to be calculated and e.g. placed in a ROM table.
You need to use a Shift Register like the 74ls165, though it recieves the data on one line you do need one or two more to control the chip.
You can also connect two or more 165s together to read in several bytes of data at once.
Hi, If the PIC has an ADC , choose appropriate resistor values and use one input to read the dip switch.
Thanks.
Why ? Could you put a few more words on this concept ?
Any idea of what appropriate resistor values would be ? (Im running 5volts on the slave)
Regards
