read_gds
omar97
Member level 1
Member level 1
hi all,
i have a problem in writing gds of whole chip that consist of memory macros and STD.
the problem is the mapping of macros isn't done.
i decide to open gds of memory macro to show what happened by using read_gds ....../memory_macro.gds
i get the following wrror massage and nothing opened:
Error: PinText "VSS" has an angle of 270.000 degrees which is not supported currently. (GDS-076)
And when opening (GDS-076) in man error:
i tells me that the allowed angles are 0/90/180/270.
what i should i do?
i generated these macros from TSMC memory compiler for 65nm LP technology.
the error is you are usign the wrong tool for the job.
Sir,
I said I open gds on klayout and don't see macro layout, so I try to open it I icc2 as klayout doesn't see any error messages.
In icc2 I found this error message.
My problem isn't how to open gds file.
My problem is, I don't know why macros isn't mapped correctly.
LaTeX Commands Quick-Menu:
