devonsc
Do you guys mind to give me some advice on how do I tap voltage the output voltage of the solar panel for ADC purposes? I'm building a boost DC/DC converter where the input of this circuit is being supplied by a solar panel.
By using a PIC microcontroller, I intend to perform some ADC set-up to read the output voltage of the solar panel to control my duty ratio of my DC/DC converter. Any advice?
Can I connect a small resistance value in series and pull a wire out from the end of the resistor for voltage reading? Is this good enough? Will this work?
Added after 48 minutes:
Would like to add on something here:
I've read about ADC using Vref. I'm not sure what it is for, do you guys mind to explain the need of the Vref? As I thought it the set-up of PIC will just take in voltage and convert to a digital level. Sorry, I'm very new in this. Mind helping? Please?
