Dar89
Junior Member level 1
- Joined
- Feb 15, 2013
- Messages
- 16
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Italy
- Activity points
- 1,412
Hello,
I'm designing a circuit with a MSV approach. I have two power domain and one power mode, since i'm using a pure MSV approach.
I usually perform a gate level simulation on the synthesized netlist in order to extract the switching activities, which i export in tcf format. Therefore in rtl compiler i read the tcf and then have a report power.
My issue is born updating the rtl compiler version to 12.2. Indeed now, in MSV designs, if i read the tcf and the male a report power, the values appear very strange ( i'm synthesizing the circuit at 3ns, but the simulation to extract tcf is performed at 1us and i want the dinamic power at 1us for comparison purposes) being 3 orders of magnitude higher than expected. Moreover if i make a report power -power_mode the tool forgets the tcf data, using the default toggle rate. These issues didn't appear with the previous rtl compiler version. Moreover if i make a standard design, without MSV approach, all works fine.
Has anyone experience with this kind of issue ?
