Sherif8
Newbie level 5
Hello Everyone,
I'm on a project that uses PCF8574A for I/O Expansion.
The controller is LM3S6918, the interface is BitBanging I2C.
I've succeeded in the write part, stuck in the read part.
will paste the code used for the read..
Please note that i use the same ack scheme in the write and read and it works for the write.
The NewByte char is always zeros
Thanks a lot,
Sherif
int main(void)
IOX_Init(0); //Board Initializations
StartCondition();
// WriteByteToIOX(0x62); //The writing commands which have been successful
// halMcuWaitUs(30);
WriteIntoPortB(); //Got a free port on the controller, connected it with the outputs of the PCF8574A
ReadByteFromIOX(); //The problematic scheme
StopCondition();
while(1);
void IOX_Init(S_DB_Interface_t *interface)
//Whatever
void StartCondition(void)
//Whatever
void StopCondition(void)
//Whatever
void WriteIntoPortB(void)
GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_1, GPIO_PIN_1);
GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_3, GPIO_PIN_3);
GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_5, GPIO_PIN_5);
GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_0, 0);
GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_2, 0);
GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_4, 0);
GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_6, 0);
void ReadByteFromIOX(void)
static unsigned char NewByte;
unsigned char x;
char i;
for(i = 0; i < 8; i++)
WriteBitToIOX(ReadSlaveAdd & 0x80); //Send the read add, 0x79, the A2 is one, Both A1 and A0 are zeros
ReadSlaveAdd <<= 1;
//Drive SCL LOW
GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_6, 0);
halMcuWaitUs(10);
//Drive SDA HIGH
GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_3, GPIO_PIN_3);
halMcuWaitUs(30);
//Drive SCL HIGH
GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_6, GPIO_PIN_6);
halMcuWaitUs(30);
//Change the direction of SDA pin into input
GPIODirModeSet(GPIO_PORTA_BASE, GPIO_PIN_3, GPIO_DIR_MODE_IN);
for (i = 0; i < 8; i++)
x = ReadBitFromIOX();
if(x)
NewByte <<= 1;
NewByte |= 0x01;
else
NewByte <<= 1;
//Drive SCL LOW
halMcuWaitUs(10);
//Drive SDA LOW
//As a receiver, the master should pull the SDA LOW to inform the ack
GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_3, 0);
halMcuWaitUs(30);
//Drive SCL HIGH
halMcuWaitUs(30);
unsigned char ReadBitFromIOX(void)
unsigned char NewBit;
//Drive SCL LOW
halMcuWaitUs(30);
NewBit = GPIOPinRead(GPIO_PORTA_BASE, GPIO_PIN_3) & 0x08;
halMcuWaitUs(60);
//Drive SCL HIGH
return NewBit;
Thanks a lot,
Sherif
