Read and Write to the parallel port?
r_pem
Newbie level 2
Newbie level 2
read and write lpt port using java
How Can I Read and Write to Parallel Port using java? Someone Plz help!!!!!
A simple google search found this:
Parallel Printer Port Access through Java
Have you ever tried to access the parallel port (printer port) inside a Java program? Well, if you have, you have probably already downloaded the commapi package that sun offers to perform this task, or tried using portio or any other thing that might resolve your problem. The fact that you are here indicates that none of these programs seem to work! And we need a solution... fast! Well folks, here it is [Windows - Linux]. It turns out that you can write code in C and Java can use it through the Java Native Interface (JNI). Take a look at the installation instructions to setup ParallelPort on your PC [Windows - Linux].
Would you please at least try to do a simple search before asking?
Java CommAPI has problems with Windows ... parallel port does not work ... solution ... go to the sun discussion forums ... a couple of guys have put their solutions there ... that will solve your problem ... you will need to copy a dll file in the respective folder ... and use the API provided instead of CommAPI to access and use the parallel port ... i can give you the exact link ... but it is better if you check out the forums ... you might find more useful things there
