re:tanner l edit spr problems...
amarnath
Advanced Member level 1
hello everybody ,after making a schematic and exporting it in tpr format..i want to do a standard cell place and route...but after initilization of spr..when i try to run it..it says ..standard cell library "row crosser" not found..this library is to be found in the setup file...iam using morbn20 from orbit semiconductor...does anybody have an idea how to resolve this problem...
Your library maybe missing the RowCrosse cell, which is compulsory to be present in the standard cell library used with L-Edit. Try checking the library for a cell labelled RowCrosser. If its not present, you could easily draw one by refering to the SPR doucmnetation of Tanner.
hello giggs,i managed to solve the problem..i installed the libraries from the cd..earlier i was using the libraries in the l-edit pro directory.../tech/mosis...so these libraries did not contain the standard cell named rowcrosser....that solved the problem...
