The video may be AC coupled in which case you will need to bias it above ground. For example 150 ohms to each supply rail.
I am not sure what you are planning to do with it, but most microcontrollers won't be capable of digitising video - the ADCs aren't fast enough. Also, it creates a lot of data.
